Im just started with 3d printing. and i need som help with a project.
Posted · Im just started with 3d printing. and i need som help with a project.
Hi. I'm sorry for my English in the forehand .
I have an idea for a project that I'm having trouble with .
I want to make a cylinder with treading on the inside on both sides of the cylinder( up and down ) . and caps for them.
I watch Youtube and haven't had any luck .
i want i like the pic. but different dimensions
100mm height
and 19.6mm diameter
    You want relatively large threads like this part:
    http://www.thingiverse.com/thing:925556
    Just as a sidenote: Fine threads are possible too. For a C-Mount lens i have printed a thread with 25.4mm diameter and ~0.75mm pitch at 0.08mm layer height and it worked better than the c-mount extension adapters made of aluminium that I bought from ebay. I only added 0.2mm to the diameter, which seems necessary for all vertical holes.
    hi guys. i have tried fusion360.[print=
    Upload your photo by drag & drop
    Choose a file
    Main image
    * Required Fields
    Enter your print details
    Used in:AerospaceArchitectureArtAutomotiveEngineeringFablabsFashionHumanitarian aidJewelryManufacturingMedicineProduct designResearchPrimary educationSecondary educationUniversityDIY, hobbies and home
    Used as:Concept modelsFunctional prototypesEnd-use partsTools, jigs and fixturesMolds and castingVisualization aidsLessons
    Layer resolution:20 micron21-40 micron41-60 micron61-80 micron81-100 micron101-120 micron121-150 micron151-200 micron201-250 micron251-300 micron
    3D printer:Ultimaker 2+Ultimaker 2 Extended+Ultimaker 2Ultimaker 2 ExtendedUltimaker 2 GoUltimaker Original+Ultimaker OriginalOther
    Print time:< 1 hour1-2 hours2-4 hours4-6 hours6-8 hours8-12 hours12-18 hours18-24 hours24-48 hours> 48 hours
    Color:BlackSilverWhiteTranslucentYellowOrangeRedPurpleMagentaPinkBlueGreenBronzeGoldBrownGlow in the DarkSpecials (wood, copper, etc.)Other
    Nozzle diameter:0.25 mm0.40 mm0.60 mm0.80 mmOther
    Material:PLAPLA FlexibleABSCPEPETNylonWoodCopperBronzeBambooCarbonIronOther
    Optional details
    Post print
    Follow and receive reply notifications
    $(function() {
    var printUploader = new Uploader();
    printUploader.init();
    $('#print-popup').find('form').parsley();
    if (util.applyUniform) {
    util.applyUniform();
    ][/print]
    do u think that it will join together?
    Nailed it! Thanks for all your help guys!
    print_printTime" name="print[printTime]" required="required">Print time:< 1 hour1-2 hours2-4 hours4-6 hours6-8 hours8-12 hours
    What?
    Screen shot or photo of your part please?
    of corse . 5a331ebb409a7_Namnls.thumb.png.268669d5cda4014a1c85fa89356ee1c4.png
    the problem i that i don't know how i maid it fit. now when i pres join it works. but when i tried to make another one it will not work..
        • 2 replies
