Should i focus more on raising the temps or lowering the fans further?
You could test both. Just edit the gcode and set the new fans&temp at the desired layer or do it manually.
I found i was underextruding the first layer starting at 200, but 205 worked good to start
Fans are at 14%...which seems to feel about as forceful as the single fan was way back when
Now to increase the temps manually as we go!
I'm curious if this temp variation is of any concern? Leave alone? Too much fan?
Any thoughts on how to improve the print quality?
@gr5 ?
.1mm layer 25mm/sec fan at 100% at 1mm nozzle temp 195C
Also if after that you still have all that ringing next to those round bumps then lower your acceleration to 2000 mm/sec/sec or instead maybe tighten the belts a bit more. Tightening or loosening the belts will change the harmonic frequency and reduce that ringing. Loosen them too much though and you get play. Lowering acceleration to 2000mm/sec/sec should reduce the jerk which will reduce the ringing also.
Ha! You didn't follow my advice. :(
.1 layer, 25mm/sec, 100% fans by the time you are at layer 1mm from bed.
Oh okay about the fans. But definitely try .1mm layer height and 25mm/sec and lower your nozzle temp some more.
Edited by GuestOld wiki explained very well how to know the correct amount of barrel to put inside the block.
Yeah, as we noted on 3dprintingforum, my nozzle isn't sitting flush. I assume the block has to be hot to get that barrel to unscrew at all
If it's cold (and assuming you never got a leak inside the peek) when cold (or 90C) you can take out the peek if you unscrew it.
To take out nozzle or barrel you need to loose the nozzle while hot (at least 150C but since you got leaks inside the alublock probably 200C so you don't force much the screws of the alu block.
Edited by Guestaluminum and brass is soft - many people have destroyed their brass parts using a simple hand wrench. Go easy! use heat! Use WD40 (works even better than liquid wrench).
Good tip (hey that's a pun!)
neotko 1,418
Print the @ultiarjan temp test
https://www.youmagine.com/designs/quick-temperature-fillament-test
I don't know if the gcode will work. But you can just print each area and increase manually the temp to see the differences. Also try to do the test with at least +5C increments.
