Olsson Block covered in Material
Kev_mc
Posted · Olsson Block covered in Material
Last week I started a print on an Ultimaker 2+, after seeing that the first layer went down OK I went off and got lunch. I came back an hour later to find that the print had failed, as there was only a solid blob of plastic attached to the nozzle of the printer, with no part in sight. In fact the Olsson block was was completely covered with plastic, to the point where I had to disassemble the print head assembly and use a heat gun to get the plastic to release enough that I actually see the Olsson block at all. All the threaded surfaces are now covered in plastic. (See attached images.) I was wondering if anyone would know the root cause as to how this happened. My best theory is that the nozzle wasn't correctly tighten and that allowed for plastic to slip around it and cause all of the problems
In summary: Print failed and the Olsson block was totally covered in plastic any suggests has to what might be the problem.5a331f6eb843d_Closeupofultimakerparts.thumb.JPG.1c8e345e8f3b07d24a461ea4de3c7ec3.JPG
    Posted (edited) · Olsson Block covered in Material
    Yes @Dim3nsioneer.  and this can happen when the steel coupler is not turned far down = lifts the block inside = makes teflon press harder..
    Or maybe you dont have the spring to press the teflon down but the little tube instead?
    In that case very important to wind the steel coupler so that there is high pressure.
    I think UM will send you a replacement part, you also need the steel coupler.
    The teflon is strong and sure like new still..
    Much more likely that the part simply detached from the platform, got stuck to the nozzle and as the printer keeps pushing out plastic it just adds to the blob on the nozzle. This can lead to some pretty impressive blobs around the whole block.
    A heat gun, a rag and some patience will clean that up no problem (I know, because I've done it a couple of times).
    So IMHO the root cause in this case was poor bed adhesion.
    Also, the nozzle is not covered under warranty (except for DOA/manufacturing defects) but if you're lucky, and your reseller is feeling generous, you might get a new one. Don't expect it though.
