Keep an eye out for browning on the UM2 circuit board - 50w is twice what the drivers and connecting traces were designed for, and could overheat things down there.
I drilled several holes in the bottom of the metal board cover for a bit of extra ventilation while using a 35w heater.
1
Labern 774
I have a 50w heater in my UM2go olsson block. It works great on every nozzle. You can print just as fast with 35w but 50w heats up faster from cold. I just wanted faster heat up times because of how the 2go heat bed setup works.
You just need to tune the pid settings which is best done with tinkergnome firmware but you can also do it in pronterface.
