This is the disadvantage of using the spacer which is now stock, instead of the spring which was the tradition. It is the part pressing the teflon down.
If the steel coupler surrounding the teflon is not adjusted to make the pressure , then you get this leak. Before UM2+, in the time of UM2, this was a more uncommon problem, since the spring would always make at least SOME pressure.
The advantage of the spacer, "korneel spacer, several variants", is that with a correctly adjusted steel coupler you can have greater pressure than with the spring, and have even less risk of leak!
What do you think @Dim3nsioneer?
valcrow 144
This happens once in a while. Don't panic!
. Just heat up the nozzle to around 90-100 and let it sit for a few minutes. Once the PLA is soft-ish, just pull it away with pliers, it should come off clean (on occasion cleaner than before) If it's too hard increase the temperature a little bit, but once you get near the nozzle, drop it back down to 90. Any higher and you will get a mess.
Dim3nsioneer 557
When it is clean again you may want to check if the heater cartridge and the temperature sensor are still sitting properly inside the heater block.
