Ultimaker Original is printing bigger on Z axis
dezels
Posted · Ultimaker Original is printing bigger on Z axis
I have some printing problems after upgrading.
Last week I bought an “Ulticontroller” and “Heatedbed” upgrade kit for my Ultimaker Original.
now I am printing with cura 15.04.6 because Cura 2.1.2 is not working very well with my Ultimaker.
After upgrading my Ultimaker Z axis scale is bigger.
15 mm box
I  checked  the jumpers on the Z stepper driver area. The first 2 jumpers installed and the 3rd jumper is not used.
My print is better scaled with all jumpers on.
(ON-ON-OFF = scale +/- 300% Z)
(ON-ON-ON = scale +/- 200% Z)
Is somebody who can help me?
Thank you!!
    Go to Control -> Motion and change the z steps to 400. A factory reset removes the adjustments you could do or had on the machine and re-reads the info of the firmware.
    Control setting:
    Accel: 4000
    Vxy-jerk: 20
    Vz-jerk: +000.40
    Ve-jerk: 5
    Vmax x: 500
    Vmax y: 500
    Vmax z: 5
    Vmax e: 25
    Amax x: 9000
    Amax y: 9000
    Amax z: 100
    Amax e: 10000
    A-retract: 3000
    Xsteps/mm: +078.74
    Ysteps/mm: +078.74
    Zsteps/mm: +0400.1
    Esteps/mm: +0836.0
    Photo :
    (What is a factory reset?) I did : calibration, bed levelling, fine-tuning.
    Maybe you can see some mistakes or errors in my settings (ulticontroller)
    Posted (edited) · Ultimaker Original is printing bigger on Z axis
    Lol sorry. 200 steps on Z change that 400.1 to 200
    Sorry for the mistake I'm at 5 thinks at the same time.
    Thank you!! It is a square! (not a rectangle anymore)
    Is it possible to set this settings? Now I am spinning 200 every time.
    You have a 'save settings' on Control -> Store memory
    Also there you have an option called 'restore failsafe' that I think it does what @IRobertI suggested. I never used it so I'm not sure if does that :D
    Thank you !!! You made my day!!
    answer :
    "set settings" :
    -Control -> Motion -> Zsteps/mm: +0200.0
    "save settings":
    -Control -> Store memory
    Thank you Neotko!!!!
