No its not as the feeder is on the wrong side of the machine and won't fit.
Dim3nsioneer 557
Well now as the UM2+ files are out it should be possible to print a mirrored version of the feeder case?
This is what I have done.
It needs a few mods as there are stepper motor screws that it will hit.
Also it's a very complicated part so needs modifying to make it easier to print.
You could probably order it SLS printed from Shapeways or a similar service?
Or you can just use my belt geared feeder upgrade to get something similar to the 2+, should fit with no problems on the UM2Go: https://www.youmagine.com/designs/belt-geared-um2-feeder-upgrade
Yes but it will not fit inside the 2go carry case
No, that would need some modification to the case.
Noone has tried to refit all the extruder into something smaller with the same parts?
I'm working on a solution.
1
- 2 weeks later...
I have Successfully printed my first parts with my UM2go+ Feeder and it worked really well. None of that tick tick tick you get when printing fast like the old feeder, I was printing with a 0.8mm Nozzle at 50mm/s and 0.25 layer height.
Labern 773
Nope, but mine soon will be.
luisito 12
But is the um2+ upgrade compatible with um go ?
