Brown spots on PCB
MTVDNA
Posted · Brown spots on PCB
Hey,
I will probably be replacing my feeder motor, so I screwed off the pcb cover to see what the connectors for the steppers look like. I noticed some brown spots on the pcb:
Is this normal? My machine has been on for about 3900 h, and has printed about 2500 h.
    Well I don't consider it normal... but mine looks the same already for a long time so it's probably no problem...
    Well, white plastic gets brown with heat. That's normal. But of course one would not see it if the plastic would have a different color. That's maybe one reason why in the past all pcbs were green or brown... ;)
    Well the Arduino is blue,..
    Thanks guys, that's reassuring. I was not looking forward to having to replace the board, this hobby is expensive enough as it is :p
    The brown spots do indicate degradation from heat.
    I drilled some holes in the metal cover under the driver area, to improve cooling there.
        • 31 replies
        • 23 replies
