DudeUser 0 Posted August 10, 2016 in Power Cord loose fit Hey, i have a problem with my Ultimake 2+ the power cord has a rlly loose fit. One move and the power cord falls down. I tried to push out the little nipples but it doesent help. Share this post Link to post Share on other sites
Labern 715 Posted August 10, 2016 in Power Cord loose fit The power cord is really tight going in to the printer. You have to push it really hard till it clicks. Share this post Link to post Share on other sites
DudeUser 0 Posted August 10, 2016 in Power Cord loose fit Does not help. No click, still loose fit. Pretty annoying when changing filament. Share this post Link to post Share on other sites
neotko 1,354 Posted August 10, 2016 in Power Cord loose fit (edited) Can you post some photos? Maybe there's something wrong with it. Also another of the connector on the printer. Edited August 10, 2016 by Guest Share this post Link to post Share on other sites
gr5 896 Posted August 10, 2016 in Power Cord loose fit This is a common problem. You aren't plugging it in all the way because the circuit board isn't centered in the hole. Loosen the 4 screws holding the circuit board - just loosen them a little - then you can plug the connector all the way on (it latches permanently and won't come off unless you slide the latch on the power cord). Then re-tighten the 4 screws that hold the circuit board in place. 1 Share this post Link to post Share on other sites
DudeUser 0 Posted August 11, 2016 in Power Cord loose fit Thank you gr 5, worked perfectly. Share this post Link to post Share on other sites
