Power Cord loose fit
DudeUser
Posted · Power Cord loose fit
This is a common problem. You aren't plugging it in all the way because the circuit board isn't centered in the hole. Loosen the 4 screws holding the circuit board - just loosen them a little - then you can plug the connector all the way on (it latches permanently and won't come off unless you slide the latch on the power cord). Then re-tighten the 4 screws that hold the circuit board in place.
