And select "MOVE'. It's right there in your photo. And move the filament an exact amount like 10mm or 100mm. Then measure the actual movement.
Before moving the material I have marked with a pen.
Then I told him to move up to 100mm and has moved 100 millimeters then it would seem that the material moves to the correct size.
It sounds like you are done then. You want an accuracy better than about 2%. So if you ask for 100mm and it moves 101mm then that's close enough. neotko would disagree with me but I've overextruded and underextruded by 5% and you can't really see any difference. I start noticing it around 30%.
You can test this live during a print. Just change the "flow%" option. This does the same thing and you can do it WHILE PRINTING.
The benefit of doing it while printing is you can change the flow ever 5 or 10 layers and mark the print with a permanent marker. and keep good notes. You get prints like this (very first photo):
https://ultimaker.com/en/community/2872-some-calibration-photographs
I recommend also a smaller print - maybe a 2cm cube. Also ignore the bottom layer as that is very very sensitive to leveling. Only pay attention to the second layer or higher.
Edited by GuestI recommend also a smaller print - maybe a 2cm cube. Also ignore the bottom layer as that is very very sensitive to leveling. Only pay attention to the second layer or higher.
OK I'll do the tests
Hi gr5 , I have done these three tests.
Before printing layer with height of 0.15 and 0.2 then to finish 0.1 naturally adapting the speed and leaving the flow always equal to 100%.
In all cases I had over-extrusion, and in the case of printing to 0.15 when in fact the upper part there was even a little is under-extrusion.
Those prints look great - I think you've got the steps/mm at the right value. However those arrows are pointing to areas where it appears to overextrude as you say.
That could be due to temperature fluctuations - that's easy to check - see if the temp is cylcing by 10C or more - for example from 220C to 230C back and forth. It could be that the wider areas are when the printer is hotter. This is a common problem when people increase the wattage of their heater but don't change PID settings.
Or more likely it could be a Z screw issue where your bed is not moving always .2mm (or .15mm etc) exactly and where sometimes it moves a little too far and sometimes not enough. There are many things that can affect Z but the most common and the easiest to fix is dirt on the Z screw. Try removing as much grease as possible along with dirt. But other possible errors include Z ball bearings need cleaning or replacing or the Z nut needs replacing.
I understand, the z axis is spotless, I clean before making the various tests, but I can tell you that before I made the change of the filament, when normally I printed with wires from 2.85mm happening to me this problem of over-extrusion only when I used a height of 0.2mm to 0.1mm but if I printed out a perfect printing!
Did you watch the temperature during a print?
You changed many things - you changed firmware which does heat differently - especially the bed temperature algorithm which draws more current in some versions of the firmware and actually changes the power supply voltage and messes up nozzle temperature.
You also may have changed the objects you print - parts that take less time per layer can show up these overextrusion errors more than larger parts. You also changed filament. Some filaments are more sensitive to temperature change.
Just turning the printer on it's side may have changed the way the ball bearings in the two vertical Z bearings sit.
Top Posters In This Topic
36
17
10
2
Popular Days
Sep 16
17
Sep 19
15
Sep 15
8
Sep 14
7
paul9 36 posts
neotko 17 posts
gr5 10 posts
meduza 2 posts
Popular Days
Sep 16 2016
Sep 19 2016
Sep 15 2016
Sep 14 2016
Posted Images
gr5 2,177
I was precise. find the MOVE menu. It's on the main screen. Play with it. Tell me what happens.
