After posting on the forum it came to mind that the blockage would be happening above the nozzle. So i let it cool and took the nozzle off; sure enough there was a small piece of filament that was stuck there and i pushed it up from the bottom.
Went on and performed the atomic method twice and now printing again.
Thanks for the help.
PS: no es mi idioma, solo vivo en Espana, y me da casi igual cual de las dos idiomas hablo, pero prefiero el ingles. Gracias.
- 1
neotko 1,417
Just to cover all chances. Are you sure that by taking out the bowden from the top, and inserting filament, you can't push or pull anything?
I only had that once that I used Esun cleaning filament after using carbonfill, the mix did fuse in an almost unbreakable cement.
Also.. What machine are you using?
Si prefieres postear tu problema en la zona del foro español también te podemos echar una mano en tu idioma.
