i really dont like Octopi so i was lookin gfor a relative cheap option with out using thatAlthough this may be an interesting tinkering with Windows 10 IoT...,
isn't Octopi the "ready to go" solution for this purpose?
Raspberry pi 3 with cura?
Out of curiosity: what's wrong with OctoPrint?
There's also AstroPrint, which started as a fork of OctoPrint.
Cant help with Win on the RasPi, but maybe take a look at Repetier Server?
https://www.repetier-server.com/
That's what I ended up using on my Pi3
Note that Windows 10 IoT is not going to be helpful in getting Cura to run on the raspberry pi, for two reasons:
1. Windows 10 IoT != Windows 10; Windows 10 IoT does not come with a desktop environment.
2. Windows 10 IoT does not run x86 binaries, so you would not be able to just run the binaries supplied by Ultimaker.
If you want to run the full Cura (frontend + engine) on the Raspberry Pi 3, your best bet would be to get the sources for all the components, and build them for the ARMv7 architecture under raspbian or the like. Start here: https://github.com/Ultimaker/cura-build
tinkergnome 924
