The idea is not to reduce warping while printing, but to reduce internal stresses that would cause problems later on during the part's service life.
A bit more about the background: when any parts are moulded in metal, glass or plastic (for example via injection moulding), they have huge amounts of internal stress moulded in due to the force of the flow that was used, and due to the always uneven cooling that follows. Edges and thin areas cool faster than the inner parts and big volumes.
If you watch transparant parts of glass or plastic under polarised light, you will see al those nice color changes due to these internal stresses. If you bend the part, you see the colors changing in the areas of stress. (I 'll see if I can find a few pictures I made years ago.)
These stresses will later on cause fatigue effects such as cracks or deformation of the part, although it may take months to show up. I have seen polycarbonate parts with fine details starting to totally crack after a year. If you leave such a part in a hot car, it is likely to deform due to the part getting closer to its melting temperature, and those stresses acting up.
To relieve these stresses, after production the parts are subjected to an elevated temperature for several hours, or sometimes even for days (especially for glass lenses). This elevated temperature is around the glass transition temperature, so that the molecules have a little bit of freedom to move, but not too much. Then they will slowly "relax" and remove stress.
When I do that with 3D-printed parts in a normal oven (I have a lab oven adjustable from room temp to +100°C), the parts will warp during the relaxation of the stress. So I need to put a weight on it, or clamp them while annealing.
However, when printed freshly, the parts are still firmly "glued" to the glass plate of the printer. So there is no need to clamp them to avoid deformation, as they can't move anyway if the bonding was good. That is the beauty of Artiz' idea to move the whole glass plate into an oven *immediately*, before it cools down and the part falls off. So he can anneal it without corners lifting.
We could use this same idea, but do the annealing in Ultimaker by using its heated build plate as an oven.
To reduce heat loss, and to get an even heating, the model has to be covered. That could easily be achieved by putting a box over it, or isomo, or something similar, if the model is not too big. I would recommend only covering the model on the glass plate with a box that is a little bit bigger than the model. Not the whole printer, so that the electronics do not get subjected to the heat longer than necessary.
In case of printing with PLA, annealing the parts may increase temperature resistance with 10 to 15°C, which may be enough for some applications. So they experience less warping when you use them in your car, for example. I have tried that: it did not eliminate warping in the sun, but it reduced it by at least 70% for my parts, which was enough. And we had a couple of very hot days this summer.
Practically, I think a good starting point to test this concept would be to use the same bed temperature for the annealing, as used for printing that part. And then see if it sags or not, and adjust temperature accordingly for the next parts. If I have time next week or the week after, I will try.
And yes, you are right that a huge drawback is that this method occupies the printer for a couple of hours. So it will not be suitable for people who are doing 24h serial production on their printers. But for others who don't print at night, they could use that time to leave the print stuck to the glass bed in the printer, and keep the heated bed on.
I hope this clarifies the idea a bit more?
I am not sure it will work, but it might be worth trying. Then the Ultimaker would double its function as both a printer and an annealing oven.
corrected typos
1
SandervG 1,522
Hi Geert, thank you for your post.
Great that you are sharing ideas, that is what everything starts with!
I can't say I heard about this technique before, so while reading I had some questions.
If I understand it correctly, the idea is among others to reduce warping, right? Warping that occurred during the print? I was wondering if that wouldn't require any physical force to 'deform' your model back in its original shape? And wouldn't the entire model get soft and potentially loose some of its dimensional accuracy?
I think not being able to use your Ultimaker for a few hours is an appealing solution to many users, except if it indeed solves some problems and you don't have a regular over available.
Could you explain the affect on uneven cooling and how that affects the strength of your print? Does it result in unequal (and bad?) layer-adhesion? And can this be fixed afterwards by this method?
Curious to hear your thoughts on this!
