1 hour ago, Jaume said:The infill close to the perimeter it's a lot more complex/different than the object's inside infill. I'd like an homogeneous infill-only object...
You need to use an infill that doesn't connect the ends of the infill lines where they meet the shell. There are settings to enable that feature.
1
berndjm 15
no idea -why- you want to do this
In Cura 2.3 this is possible.
Just set "Wall Line Count" (Wall Thickness), "Top Layers" (Top Thickness), "Bottom Layers" (Bottom Thickness) to 0.
Regards Bernd
Jaume 1
I'm also interested in a infill-only print. Setting the wall line count and the others to 0 kind of does it but not really.
Any help welcome!
Edited by JaumeLink to post
