Posted · Cura 2.3.0 splash screen then nothing else
Well this is annoying, the beta ran alright. While loading some large parts this evening, Cura sat on "preparing to slice" for a long time, never doing anything.
I downloaded the Windows 64-bit version and installed that. Allowed it to uninstall the beta and then install.
At the end of the installation and option to run Cura, nothing happened.
I tried the install again. No splash screen. Even checked the task manager...no where to be found
Cleared temp files (CCleaner), reboot....install again.
Now when I launch Cura I get the splash screen but nothing else.
Windows 10 (latest build) 64 bit. Help
From beta to final it was problematic to have temp files of previous versions. Maybe it needs a full Cura cleaning but I don't use windows (thank god :D )
Maybe there's config file making your cura banana.
    CCLeaner cleans up temp file and so on (seriously good program, Google it)
    Well I expected better than "Thank God I run a Mac" from support. My goodness.
    I think you are better off removing all the files yourself.
    Oh I was just pulling your leg since we know each others, don't worry I will answer on a professional and serious manner.
    Text comes across dry...my response was [intended] to be humorous too.
    So remove the folder under Program files and try again? Will do.
    Holy we need more emojis
    I think that if cura works like on mac it might do temp files on other folders.
    Well, as detailed elsewhere, I have the exact same problem on my work computer.
    That's running Windows 7 64-bit
    Un-installed 2.3.0
    Deleted the Program Files \ Cura 2.3.0
    Re-installed.
    At end of install, selected "Run after install" Nothing happened.
    Launched Cura 2.3.0 from Start - All Programs - Cura 2.3.0
    Splash screen loads, starts load up steps...then vanishes
    What should I try next?
    Maybe a full search for cura word on the hard disk. Maybe the beta left some files that are causing conflict?
    Well I don't want to loose 15.4.2 as I have those settings set for my UMO
    Awaiting some troubleshooting tips from the developers
    Posted (edited) · Cura 2.3.0 splash screen then nothing else
    Have you tried renaming c:\users\[your name]\appdata\local\cura to cura.bak?
    I'll check from home
    Unable to find that on the work PC (could be permissions on the work computer)
    Sorry, it is "AppData" instead of "Application Data". You may have to type in the path, because the "AppData" folder is hidden by default.
    That worked....renamed the folder and installed it again
    Good...that was the folder I meant above when I just wrote "cura user folder" :p
    Glad to hear you are back on track again :)
    Installing again was not necessary. Could you zip up the renamed folder and post it somewhere so that we can figure out what is happening?
    Correct, on my work PC I just renamed the folder and now it is working.
    @ahoeben , message me your email and I will send the zipped folder to you
    Oh wait, I have @nallath 's email, I will send it to him
    @ahoeben,
    @Nallath emailed back with some good information
    I also placed your suggestion as the Best Answer, in case others run into a similar issue
    Thanks. Any info worth sharing in the email from Nallath?
    I'll let him answer that
    Uh, LePaul also tested 1.99, which also left some profiles behind. Those profiles never got a proper upgrade plugin, but the 2.1 to 2.3 upgrader did try and upgrade them, which led to horrible results (profiles with type machine_instance_profile).
