I opened an issue: https://github.com/Ultimaker/Cura/issues/1084
1
Hi @nallath I have never need to look at a Cura log file, where is it stored?
@yellowshark: On the Mac it is located at ~/Library/Application Support/Cura/cura.log.
Thanks it was elsewhere in the directory structure but your "cura.log" found it for me . Hi @nallath where do you want me to send it?
That's weird. Where was it located on your machine?
~/Appdata/Local/Cura/Cura.log
DM is fine.
Experiencing same issue here.
I can send you the log if it would help the effort.
cheers
chris
Also, when a new printer is created, Cura does not recognize it when restarted.
It is working with 2.3.1which I loaded yesterday. There is a funny though; I am in conversation with Support and will report back once that is resolved or I find out what I am doing wrong.
BTW you need to change file suffix .inst.cfg to .curaprofile when you import. I do not know for sure but if you Export I assume Cura does that.
v2.3.1 seems to have fixed the profile import issue.
chris
Edited by Guestv2.3.1 is also VERY slow to load. I've got a fairly fast machine with an SSD and it never takes less than 30 seconds.
cd
I have the same problem but I've just updated Cura to 2.4. I'm trying to import this profile for the mp select mini, every time I import the file it gives me a success popup but then the profile is not available to select. Any ideas?
Nicolinux 288
@yellowshark: In the meantime you could just look at the profiles themselves without importing them. I think they are zipped text files. And since the profiles aren't fully exported but just a diff to the default profile (which I think is a big mistake), you can see which settings you need to apply.
