I don't know what you mean by in the first layer.
As you can see in the picture, there should be everything alright in Cura.
To describe it more precisely, the motor behind which feeds the filament works, because it feeds while printing the first layer and the support structure. After the progress you can see on the picture, the filament feeding motor stops working. I really cannot tell what the problem is.
So you can see it prints the first layer perfecctly and afterwards there is simply no filament coming out.
peggyb 170
Do you mean this is all happening in the first layer?
Did you look at the layer view in Cura if everything is correct?
Can you make a picture of your print?
