It would cut printing times by a lot if you could print only the outer layer with 0,06 layer height and small nozzle and use the other nozzle for infills and inner shells. So you don't have to print the whole object with the highest detail if there are large straight walls for example. It would help the print cleanup and prepping models for painting quite a bit.
Cura can already do that, albeit it is not easy. I'm trying to get a "how-to" written, because with some instructions I think everyone can manage.
Here in UM HQ we're combining 0.4mm print core with 0.1 layerheight (for the outside) with 0.8mm print core with 0.4 layerheight (for the inside).
The result is a beautiful print at more than 50% reduced print time.
2
Labern 772
Just so you know. 3D solex has been selling 0.15 and 0.1mm nozzles for quite some time
Edited by GuestLink to post
Fiskare 0
Yes I'm aware that there are many smaller nozzles out there, but what I would be most interested about is the dual extrusion with different sized nozzles/layer heights. So you can make the base of the part with a larger nozzle and add the details with the smaller.
So I was wondering if there is something in the works or if someone has made it work already. Since Cura doesn't seem to support different layer heights on each core yet.
