Posted · saving program setting and not just the machine setting
I can not see where you can save your programm setting.
The machine setting can be save as profile, that is easy.
but if you have a builtup of several STL files on your table, all lined out that there is maximum parts and still good space, then i can't save that.
is this not something that more people would need, or have i overlooked something?
    Give me a "C", give me a "u", give me a "r", give me a "a", give me a "2", give me a ".", give me a "4"
    What do you get?
    Workspace saving!
    • Like 2
    2.4 will be able to do this. We've merged that feature into master today.
    3MF model saving does the following;
    1. Save all objects on your build plate, including grouping
    2. Save all per object settings attached to objects on your build plate (including extruder assignment)
    3mf workspace saving does;
    1. Everything that 3mf model saving does
    2. Save the active machine, profiles, materials, etc
    3. Save visibility & collapsed state of settings
    It can even save custom machines, so that it can be loaded into a Cura version that doesn't even have that machine definition (which makes it a whole lot easier to share them!)
    • Like 2
