Recommend to get a 3d printer that is used, if your not going for one of the most cheap 3d printers that is to say. I would look closer to the specs that you have as minimum requirement and check prices. I've had read a lot about 3d-printers on alla3dskrivare, site is in Swedish so I would recommend you check around https://www.3dhubs.com/best-3d-printer-guide for more information about good 3d printers.
I think it would be a good idea to have a test part printed on various machines, via a 3d-hub service, or via hobby clubs in your environment, and see which models deliver the quality you want.
Instead of buying a cheap assembled model, you could also consider buying a do-it-yourself kit. This will generally give you a bigger and better printer for the same amount of money. But this only works if you have enough technical insight to assemble it yourself, of course. If you are not confident in assembling such a complex thing, it could become a nightmare.
bob-hepple 59
I got a Anet A-8 for about £120 it has heated bed kit form though I got it for a friend of mine who is into machining so he could get into 3D Printing as well as satisfy his urge to Machine. Kit looked good
- 2 months later...
Recommend to get a 3d printer that is used, if your not going for one of the most cheap 3d printers that is to say. I would look closer to the specs that you have as minimum requirement and check prices. I've had read a lot about 3d-printers on alla3dskrivare, site is in Swedish so I would recommend you check around https://www.3dprintmanual.com/best-cheap-3d-printers/ for more information about good 3d printers.
gr5 2,210
It depends on how low quality you are willing to go and how much money you are willing to spend. For me, it would probably be the prusa i3. But maybe that's too expensive for you. I wouldn't want quality any worse than that machine and I think it's the best deal for that level of quality. If you want to spend a bit more then of course go for the UMO.
Even better, get a used printer. The price is lower and the quality is better.
