Ultimaker filament feeder bowden tube replacement to direct drive.
Posted (edited) · Ultimaker filament feeder bowden tube replacement to direct drive.
Hi all.
       Just uploaded my latest Ultimaker mod to youtube k9JoSJg7SIQ
        Rod
  • 2 weeks later...
Posted · Ultimaker filament feeder bowden tube replacement to direct drive.
Hi print quality is very good. more consistant than with the bowden tube feeder.
Rod019.thumb.JPG.102c38c07f5a6ee9c4102c5cf720f2fd.JPG[/media][/media][/media][/media][/media]
    That's a pretty cool a idea to make a lightweight direct drive, i'm guessing that the extra weight is not that much and has no impact on vibrations when printing faster.
    Are you planning to make it available somewhere ? The gears are metal or printed? Are you using the same motor as the original feeder?
    Awesome work anyway!
    Hi
    Feedhead weight now 49grms .I removed the material cooling fans scrouding ect a year ago and replaced with air from a pump witch fans out just below the hot end nozzle .The only fan i use is to cool my hotend setup whitch is not standard
    so should be a lot lighter than the original. Bevel gears are brass motor is the
    original ultimaker material feed motor.As to making feeder a kit all depends on the
    cost and feedback i get back.Now working on idears fo MK 2.
    Thanks all for your interest.
    Rod.
    Hi just finished latest mod to enable 017.thumb.JPG.de69860aee84063cf3d8952571945da0.JPGme [/media]to remove printhead feeder assembly
    allowing me to change ptfe or to convert to use 1.7 filliment.By removing the
    single screw in the centre of the printhead an lifting up takes about 10 sec.025.thumb.JPG.3282417c1b5aa79614c66523cd0475d4.JPG
    019.thumb.JPG.28e5791a9d3654323d427d563ffff0ea.JPGRod
    Looks like you picked the right username for this drive feature :)
    Hi Thanks.
    The bowden fan is an interesting idea.
    https://ultimaker.com/en/community/3435-new-fan-cooling-design#reply-19327
    https://ultimaker.com/en/community/3435-new-fan-cooling-design#reply-19299
    Hi replacing the fans with an airjet has worked out well for me as it gives
    me more control of temp when printing.Fans can produce to mutch air to the wrong place that can have an adverse efect on buildplate temp and nozzle temp
    resulting in bad prints and other problems plus they add extra weight to the moving printhead. I printed a Tourbillon watch by Christoph Laimer with the airjet with very few problems.
    Rod001.thumb.JPG.aae9fe819abcd2bc6239d78e51e60882.JPG[/media]
    Hi
    Just finished latest mod to Bowden tube feeder replacement to enable me to feed and print 1.75 Ninjaflex flexable filliment. Test prints turned out as good as PLA or
    better.
    Rod003.thumb.JPG.8c2a55d1d920b95ebfe68fb76794ae1c.JPG[/media][/media]
    Hi
    A few more mods plus tidy up and weight reduction off moving parts.
    1/ Manual feed wheel added to step motor.
    2/Steel cross material feed shaft replaced with carbon fibre shaft.
    3/Carbon fibre shaft and bearing added to support any pull on head by filliment that might effect print quality.
        • 2 replies
