if you have issues with strength with NGEN, try printing warmer... what temp are you using now?
234 no fan
I found that all the blobs on the nozzle vanished once the fan was shut off. I had been running 50% and the nozzle was a mess after
I need to find a test model I can strength test (something tall) with the various infills
234 no fan
try running this at 245 if you have an UM2+.. you'll get better results.. only use fan with NGEN during overhangs..
Ok, I found this strength test piece gr5 made a while back
https://www.youmagine.com/designs/strength-tests
I'm going to see what a piece printed at 245C and 50% infill does, using the default infill (Lines) I'll do another using Triangles and compare!
Print underway and I can already tell 245C is too hot as the first layer has "tidal waves" (best description I have) in it. But I'll see this print through.
So on the two models that printed at 245...
Model one snapped quickly with the triangle infill
Model two hasn't! Just using lines for infill
Both have ugly bottoms from printing at 245C
Edited by GuestOkay so it's late and we have an ice storm under way, so I didn't print as much as I wanted to. But I am afraid the power will fail soon!
Here's the last two I printed.
The 240C print with tetrahedral failed with little force
The 240C print with lines survived my testing
240C still seems a bit too hot based on the first layer 'waves' (as soon on the bottom as well)
Some of this is more a hassle with fine tuning nGen for strength (if it can be)
But I'm intrigued the more elaborate infills are failing so easily
Well, bummer. I would have thought the triangles would have held up better. Guess you can't believe everything you read on the Internet :(
- 1
Yeah I'm just putting the samples about half way off the counter and putting some force on the end...nothing crazy, just slowly applying force with my hand. I was quite surprised how quickly the two orange pieces blew apart.
I had been printing at 230C and getting really nice adhesion. I'll see what 235C does tomorrow (again, no fans on any of these prints)
My guess would be the orientation of the lines is providing greater surface area across where the force is being applied, specifically layer to layer. If you were looking at a compression force along the sides (perpendicular to the z-axis of the print) I would imagine the triangles would hold up to more.
That's a good point
I could print a small scale version of that frame piece in "Lines" infill and "Triangles" and see how that goes.
Last night I printed a 50% version of the frame piece (curved piece a couple posts above). I printed at 235C and used the triangles infill. When completed, I twisted, pushed, pulled and the piece stayed intact!
I think I will print the full size one tonight and go back to my 230C settings and use triangle infill to see if that's the secret to a stronger print with nGen. And I can also do a 235C one to compare the strength between temps
LePaul: Thanks for sharing! This is great stuff to know.
DaHai8 74
This article suggests the second-best option to hexagon (honey comb) is Triangular (Triangles):
How to Choose an Infill for Your 3D Prints
Edited by GuestLink to post
LePaul 330
Thank you, thank you! That's a really great read! Ultimaker should have something like this in the Cura help pages! @SandervG
