Why does this post look almost identical to this other one?
https://ultimaker.com/en/community/36076-too-much-retraction-at-the-end
1
Thanks for pointing that out krys. All 3 of his posts were copies of other people's posts and all 3 had a link to his website. He is banned.
I have tried updating the firmware, but it still happens.
the print quality is fine.
krys & gr5? has someone copied my post? can't see on that link
Edited by GuestSince you've upgraded the firmware - have you tried resetting to factory defaults after the upgrade? Sometimes weird things happen after flashing your machine.
From what Gr5 said, yes, someone was copying other peoples posts (including yours here) and adding a link back to their site. I happen to notice 2 posts with almost identical wording so I asked. Gr5 said the other person is now banned.
Glad to hear your post is an original!
Also, I agree with SyntaxTerror. You need to factory reset your printer after replacing the firmware or weird stuff happens. Happened to me! But: a) Your print time stats are preserved, so fear not, and b) you should take out your filament first and the printer will do the brand new first time start up routine again.
Anyway, good luck!
We get a lot of spammers on here. The moderators take care of it so that you rarely can see any of them. They are usually blatant. I deleted 10 pages of spam today. the spammers don't realize that their posts are never visible to anyone other than moderators so they think they are successful. I'm hoping that will change soon.
Sander has often joked that maybe we should allow the spam and Ultimaker should start selling penis enlargement pills.
Anyway that one guy got through. He copied 3 posts somewhat randomly and changed a few words. It's extra annoying because I tried to help the guy with his question. Thanks to krys for noticing.
Brilliant idea.
Anyway I will try what has been suggested and let you know how I get on
ok, so I reinstalled the firmware using the latest cura, then did a factory reset, seems ok now
thanks
Yeah, I figured. Always factory reset after messing with the firmware. Not doing so seems to invite those mindboggling issues.
lets reignite this thread.
It didn't last long at all which is weird. Still having the same problem
Which problem? Too much retraction?
ultiarjan 1,221
did you update firmware and the problem is still there? or did you not manage to update the firmware?
Apart from this your print quality good?
In the mean time (not a solution but helpful anyhow) you can much quicker push the material in manually by just pulling the lever on the feeder and pushing in the filament by hand.
I always change material manually..... this thing is helpful;
https://www.youmagine.com/designs/wedgebot-for-ultimaker2
