limeyboy 0 Posted January 20, 2017 in UM2+ Z-Axis Low At Start [**SOLVED**] (edited) Hello This forum has been a big help to me, thanks to all that take the time to respond. I did search but could not find a similar fault/fix. Had an UM2 for 3 years - no real issues. Two weeks ago I upgraded to the + (including firmware) and since then I've had intermittent issues with the start of the print. The nozzle will be anywhere from 1mm to 5mm away from the bed for the first layer, so it prints in fresh air. Bed leveling / calibration = makes no difference (tried 10+ times - bed is level and just a bit of friction between the paper and nozzle) Factory reset = made no difference Sometimes I power off the printer, power immediately back on, start the print and all is good - even if 30 secs ago it was printing in fresh air. Sometimes I need to do this 4-5 times before it works. As an additional note: At the same time this ^ fault appeared, I started to get the error 'Error stopped - Z switch stuck' - but powering off and on clears it every time. Both are intermittent issues - if there is no Z error and the first layer is down correct - the print turns out great. Thanks for any suggestions (that won't cost me more money ) JW Edited March 9, 2017 by Guest Share this post Link to post Share on other sites
neotko 1,355 Posted January 20, 2017 in UM2+ Z-Axis Low At Start [**SOLVED**] Check if the Z screw (the one below the bed that actually touches the endstop) is properly tight or wiggles. I would also inspect the Z endstop (share a photo), maybe the metal is bent. Share this post Link to post Share on other sites
limeyboy 0 Posted January 21, 2017 in UM2+ Z-Axis Low At Start [**SOLVED**] Thanks neotko I checked the Z screw is tight and centered and the Z switch is triggering (multimeter on the switch). Not sure what the "Z Endstop" is? Bed stops when the 3 bed levelling screw heads contact the base. Can anyone tell me (or point me to) the sequence that triggers the "Z stuck" error because what I don't understand is how: The bed can be down, I press to start a print and without the Z axis moving or trying to move at all = Z stuck error comes up. I could understand: - Bed moving down, switch does not on = error - Bed moving up, switch does not go off = error But how does zero movement trigger an error? Thanks again. JW Share this post Link to post Share on other sites
limeyboy 0 Posted January 25, 2017 in UM2+ Z-Axis Low At Start [**SOLVED**] So does anyone have any further ideas before I contact Ultimaker support? I am still having two intermittent issues: - Print starts with bed too far away (down) from nozzle - Z switch stuck error (I'd still like to know the logic conditions that trigger this message...) Here is what I have done since first post above: - Factory reset again - Re-levelled the bed - many times - Checked the z-switch is working - both at the switch and on the board - Checked the board - to make sure everything is where it is supposed to be and there are no lose connections after the UM2+ upgrade. - Deleted the UM2+ machine profile in Cura - downloaded default firmware for UM2 - (I cannot actually run as an UM2 now I have the UM2+ upgrade because the feeder runs in the opposite direction running UM2 firmware). - Re-installed UM2+ machine profile in Cura - downloaded default firmware for UM2+. Since Saturday I have had two good prints and approx 20 aborted soon after start - due to one of the above errors. Because I had so many uneventful prints over 3 years before fitting the UM2+ upgrade I am currently convinced it is the upgrade, probably firmware, that has caused both these issues to come up. Or this is a bad coincidence. Cheers for any pointers. JW Share this post Link to post Share on other sites
tinkergnome 587 Posted January 25, 2017 in UM2+ Z-Axis Low At Start [**SOLVED**] So does anyone have any further ideas before I contact Ultimaker support? mmmhh, are you sure, that you have placed the plug of the small 5V fan at the correct connector ("Fan 5V" J34)? If you accidently plugged it to the 8/16 STEP (JP3)...this would explain your symptoms... Share this post Link to post Share on other sites
limeyboy 0 Posted January 25, 2017 in UM2+ Z-Axis Low At Start [**SOLVED**] So does anyone have any further ideas before I contact Ultimaker support? mmmhh, are you sure, that you have placed the plug of the small 5V fan at the correct connector ("Fan 5V" J34)? If you accidently plugged it to the 8/16 STEP (JP3)...this would explain your symptoms... Yes I went back to the circuit board and verified this connection - I've searched posts and tried most of the ideas for any "Z" axis issues - and I saw that one come up a couple of times. This is also an intermittent issue - every now and then (not often) - a print starts and ends well. Thanks for the idea though - any more nuggets? JW Share this post Link to post Share on other sites
LePaul 280 Posted January 25, 2017 in UM2+ Z-Axis Low At Start [**SOLVED**] I think now is a good time to get @Sandervg involved! Share this post Link to post Share on other sites
limeyboy 0 Posted January 26, 2017 in UM2+ Z-Axis Low At Start [**SOLVED**] I think now is a good time to get @Sandervg involved! What is the best way to contact Sandervg or Ultimaker Tech Support? Cheers JW Share this post Link to post Share on other sites
limeyboy 0 Posted March 9, 2017 in UM2+ Z-Axis Low At Start [**SOLVED**] SOLVED I was put in touch with local support = FBRC8 located in Memphis, TN. I have to say they were great through the diagnosis, good frequent contact with solid ideas to try. After checking a few wires and settings (all ok), I downloaded Pronterface. All the checks in Pronterface came back ok as well. Eventually Spencer @ FBRC8 said to send it in to them - they provided the packaging and shipping note and within a couple of days after receiving the printer they said the Z-Motor was bad. One clue here was they said it should be possible to raise the bed by hand lifting on the bed - I had to manually raise the bed by also turning the Z-screw shaft at the same time as lifting on the bed. So the Z-motor was sticking at certain points which explained why it must have lost its position and was trying to start prints with a 5mm gap between the nozzle and the bed. The Z-switch stuck error had to have been related to the Z-Motor. FBRC8 replaced the Z-motor, calibrated etc and determined all was well again. I will say that the second e-mail I got from FBRC8 back at start of Feb mentioned the possibility that the Z-motor may be bad - so they nailed it early - but tests I performed did not immediately back that up. I am happily back printing excellent quality parts as I am used to with my UM2. Big thanks to FBRC8 and especially Spencer - good support all around and based off this experience I recommend them highly. Thanks also to those that posted here with ideas for me to try. Cheers. Share this post Link to post Share on other sites
LePaul 280 Posted March 9, 2017 in UM2+ Z-Axis Low At Start [**SOLVED**] Fabrc8 are good people! Glad you are back up and running! Share this post Link to post Share on other sites
fbrc8-erin 107 Posted March 10, 2017 in UM2+ Z-Axis Low At Start [**SOLVED**] Thanks, Limeyboy! We try our best. Glad to get you back up and printing again. Share this post Link to post Share on other sites
