In addition note that white filaments of all brands have something in it (I think talc) that makes it harder to print.
The thing is that before it worked as good as any other colour I have used so far (s. e. g.:
Also it looks to me like you don't squish your filament as much as I do and you don't appear to use any kind of PVA. Squish and PVA when done correctly keep the bottom layer from peeling.
What do you mean with "squish"? Regarding PVA I tried to use the glue that came with the printer, but that didn't help a bit!
So I will order a new nozzle and try again!
THANKS!
- 1
gr5 2,210
It's probably the nozzle. It's probably worn. Swap out the nozzle. Let us know if that works.
Edited by GuestLink to post
