Hey @devilflash, I had a similar issue with an older Tinkergnome firmware and I saw somebody else reporting something that could be related. Basically the print head goes into super slow-motion mode but still moves. If this happens again, try to determine if that's the case. Would help tinkergnome debug the problem.
My printer seemed to have problems with the ribbon cables connecting the display to the board. I just reversed them - took them out, rotated them by 180° and connected them again - of course respecting the cable's polarity.
I didn't have any freezes since then. However, at the same time I started using an experimental tinker firmware which uses the old sd card loading code (which I think is part of v16.12.1 anyway now).
SandervG 1,522
@tinkergnome, do you think this could have to do with the firmware?
