Thank you so much for responding!
How many atomics done? Maybe is just some left particles of other filament or dirt. I would keep doing stomics until they come clean. Also maybe, if is abs debris, it might need an atomic with abs or with nylon.
Have done at LEAST 10 over the past few days. Have only ever used high-quality PLA with this printer.
Could you post photos of the hotend to see if there's something wrong? Also double check that the bowden doesn't pop and is fully inserted into the ptfe coupler.
We had an earlier issue with molten PLA oozing on top of the heater block. Per suggestions here, heated the block until the PLA was pliable and scraped it off. After tightening the hot end isolator tube (while the block was warm) seemed to fix the leak. Still have some PLA lingering around the assembly - planning on working on this later
Bowden is fully inserted when assembled. If it gives you (or anyone else) any additional clues, when we do a test print, the first few layers come out just fine, but get progressively spaced out and messy before the printhead stops extruding all together. Example below:
Thanks again for problem solving with me. We are so frustrated at the moment...
neotko 1,417
I would not change much. The first things that can damage over time to s the ptfe coupler, and ofc the nozzle (even though it can last years and years if you don't use abrasive materials).
