Maybe a simple option is to use the signal of the fans? Pwm control in gcode out of the box.
The breakout PCB syntax terror is working on will give even separate fan control in dual extrusion setup. (the PCB is part of the magnetic toolchanger beta)
Another option is to use the signal of the printers led's. Also control able from gcode.
Edited by SandervG-
2
foehnsturm 969
Interesting project!
@SyntaxTerror is working on a small device that probably can be used for this purpose (depending on the required amperage).
