Do you still know which AA core was in the left slot?
That's important because factory XY calibrations are done with that core in that position.
(Every core has a unique number, and XY calibration of a set of cores is remembered by the printer)
I'm not sure I understand your problem entirely. Your BB core is recognized by the printer, but is identified as an AA? That would be a factory mistake. Or is it not recognized at all?
You can look up printer info on the printer (by heart: system->maintenance->printer info?). There you will find info about the currently loaded print-cores.
Contact your reseller if your BB core identifies itself as AA.
The PVA nozzle is tested with black PLA in our factory, that is the black stuff that you see coming from the nozzle. The small silver-black printed part in your box is printed with your printer with your nozzles!
gr5 2,070
The power cable is easy to fix - it is supposed to go further in and snap in place and shouldn't pull out easily. Sometimes the circuit board that holds the connector is pushed to the side. To fix, loosen the 4 screws for that circuitboard (just guess) and plug in power and move around and verify it is loose and then tighten the 4 screws again.
As long as temperature is below 50C for both cores you can remove a core and re-insert and the top needs to snap in as well as the bottom. At that point the printer will re-read the eeprom on the core. Are you saying the BB core reads as an AA at that point? If so it's probably just the eeprom that is wrong. It's possible to reprogram it if you are familiar with ssh. But maybe easier to just send it back. But you *can* just print anyway. Even though it won't let you select PVA for the second core you can print something sliced in cura meant for pva in second core.
