thanks for your reply,
I don't know where I can put it, do you have a suggestion ?
Unless its really large, you can post it inside a message here using the 'code' tags from the menu >
the plugin is to determine the area used by the first layer to optimize auto-leveling
I never learn python, so I took exemple from other plugins.
it searches min and max X Y position of G1 command and replace a specific string of the start gcode by the optimized G29 L R F B command
from ..Script import Scriptfrom UM.Logger import Loggerimport reclass G29_PH(Script): def __init__(self): super().__init__() def getSettingData(self): return { "label":"G29 by PH", "key": "G29_PH", "settings": { "AutoLevel": { "label": "G29 by PH", "description": "determine Autolevel optimise", "type": "boolean", "default": False, "visible": True }, "Marge": { "label": "Marge", "description": "Marge ajoutee a la zone d'impression pour l'autolevel", "unit": "mm", "type": "float", "default": 2.0, "visible": True, "enabled": "AutoLevel == True" }, } } } def getValue(self, line, key, default = None): if not key in line or (";" in line and line.find(key) > line.find(";") and not ";TweakAtZ" in key and not ";LAYER:" in key): return default subPart = line[line.find(key) + len(key):] #allows for string lengths larger than 1 if ";TweakAtZ" in key: m = re.search("^[0-4]", subPart) elif ";LAYER:" in key: m = re.search("^[+-]?[0-9]*", subPart) else: #the minus at the beginning allows for negative values, e.g. for delta printers m = re.search("^[-]?[0-9]+\.?[0-9]*", subPart) if m == None: return default try: return float(m.group(0)) except: return default def execute(self, data): lines = data[1].split("\n") data1_temp = "" bbL = None bbR = None bbF = None bbB = None layer = -1 marge = self.getSettingValueByKey("Marge") for line in lines: if ";LAYER:" in line: #new layer no. found layer = self.getValue(line, ";LAYER:", layer) if "G1 " in line and layer == 0 : x = self.getValue(line, "X", None) y = self.getValue(line, "Y", None) if x != None: if bbL == None: bbL = x else : if x < bbL: bbL = x; if bbR == None: bbR = x else : if x > bbR: bbR = x; if y != None: if bbB == None: bbB = y else : if y > bbB: bbB = y; if bbF == None: bbF = y else : if y < bbF: bbF = y; bbL -= marge bbR += marge bbF -= marge bbB += marge for line in lines: if "G29 L R F B ;Auto Bed Leveling" in line: data1_temp += "G29 L" + repr(bbL) +" R" + repr(bbR) + " F" + repr(bbF) + " B" + repr(bbB) +"; PH Auto Bed Leveling\n" else: data1_temp += line + "\n" data[1] = data1_temp # "G29 L R F B ;Auto Bed Leveling" return data
thanks for your help
It works well on my MAC with CURA 2.1.3
but not on my Win10 with CURA 2.4 : the list of post processing plugin show only one plugin when I had the file (normally it shows 4)
an other issue/question :
is it normal than even on CURA 2.1.3 the post processing is not saved when I reopen CURA ?
Edited by GuestHello,
could you tell me how I could add a python script to cura 2.4 on a Mac.
I tried to place it in the plugins folder under the cura folder, but won't work.
It's a python script with works under windows.
Thank you for your feedback.
Regards
Ralf
The API has changed between 2.1 and 2.3 - look at existing plugins to see what's changed (getSettingData vs getSettingDataString)
Yes, it is "by design"
If you are talking about the PostProcessing scripts, on OSX they are in Cura.app/Contents/Resources/plugins/plugins/PostProcessingPlugin/scripts/
Where could I find this folder?
Regards
Ralf
At the place you installed Cura...
So for most people it would be: /Applications/Cura.app/Contents/Resources/plugins/plugins/PostProcessingPlugin/scripts/ (unless you installed it somewhere else)
... and where will Cura 2.4 be installed when installed(?) or run from Cura-2.4.0.AppImage-Install (the new Linux installer)?
Regards, Martin
I see no reason why it should be different in 2.4...
But I can't answer that formally, my personal experience tells me it is not always a good idea to be early adopter of new Cura releases, so I am still with 2.3 for now
ahoeben 2,047
Post the plugin somewhere, and somebody may be able to help.
