Also look in to OctoPrint. I find it much more convenient to print directly from Cura to the printer via OctoPrint without swapping SD cards. Going the OctoPrint route vs using the USB connection gives you much the same benefits of using the SD Card (ie: stability, not having to keep your main computer on, etc), and a whole host of other perks such as the possibility of remote monitoring.
1
bsilverwood 8
Cura 2.4 has a print via USB option available.
