I understand, but it is impossible to move an object with any precision as Cura keeps on slicing when I move the mouse!
Is it possible to move several objects all together?
I have ten times the same object. They should fit nicely in two rows of five on the bed, but the automatic function puts them in only one row with two items completely out of the bed! Why does this function no longer work as it used to?
1
ahoeben 1,968
It should definitely be possible to move the objects to a better location.
Click on an object, then drag it around. You may have to (re-)select the Move tool.
