A bit late, but still: in car tuning shops, they do have spray paints that give a chrome or gold effect (or any other desired colors with mirror-effect, as in christmas balls).
On Youtube you find a lot of demo videos. Search for "spray on chrome", or "spray paint mirror chrome effect", or similar.
It seems to consist of cleaning, spraying on an activator, rinsing with water, spraying on chrome, rinsing with water again, spraying on a sealant varnish, rinsing, drying with compressed air. It also seems to work well on flexible materials, even leather.
For example these:
1
cloakfiend 990
Galvanisation requires only 30 degrees heat max. And is fairly painless and will achieve a glossy reflective finish with no sanding. However the solution you do it in is corrosive and you need to wear gloves. But you also need a good print to begin with. First choose either nickel or copper to plate with if you want to do it yourself easily or take it to get chromed somewhere else at a cost.
Edited by GuestLink to post
fergazz 60
Thank you for the feedback.
I will definitely try nickel, copper and how cost is to get chomed outside.
By the way I found a great beginner source written by "Enza3D" to anyone looking for post processing tips, Metal Plating (the right name for "metal looks like"
) is on the bottom of the page:
https://www.3dhubs.com/knowledge-base/post-processing-fdm-printed-parts#introduction
For those looking for advanced tips just follow @cloakfiend specially his topic about "Blended PLA with acetone" or something like that... awesome stuff!
