fbrc8-erin 265
Also make sure there's no filament hanging off the end of the nozzle; it will throw off the height calculation.
If that and making sure the glass is clean don't do the trick, tighten your bed springs a little.
After the bed goes up at high speed, the measurement starts when the bed starts moving very slow (0.4mm/s).
At that moment, there must be ~1mm gap between nozzle and bed. If the bed is too high, the measurement will start with the bed against the nozzle. That won't work.
When you see that, turn the screws below your bed to lower it slightly.
I got the same message after upgrading the firmware. Till yesterday all works fine. But now I need 2-3 starts before the printer is working well. Sometimes the message came - sometimes not. The glass is clean and the nozzles too. That would came with the update I guess.
That is not nornal. Contact your reseller for help.
I found that when I had this error (after making sure the nozzles are clean and such), it required me to reset the manual leveling as the bed can be knocked out of alignment if you are not careful when removing a print. I found it better to just remove the build plate when removing a print.
That made me get a couple of extra build plates so I can just cycle through them and check the active leveling after each build plate change and before starting new print.
I always figure I am knocking something out of alignment. And, that has proven to be the case most times if I am too 'rough' when removing a print of build plate.
Some help with this (reasons why / possible solutions) can be found on the UM website:
Dim3nsioneer 556
Make sure there is nothing between glass and heater pcb of the bed. Small particles, e.g. from pva after taking the glass out, can have this effect.
