Totally agree with Daid, the small brass tube gets violated by users all the time, to a point where UM should simply drop 2 into each box... PEEK is the most annoying should you decide to burn it up, together with ripping the TC out with brutal force, since they are difficult to find&replace. everything else can be found everywhere.
Daid 303
PEEK and the brass tube are most common to break (during assembly or a temperature sensor connection failure)
I've never seen the alu-plate being damaged.
Electronics can be damaged, but they are quite expensive to have "on stock". Spare stepper driver might be nice to have, as sometimes they break (but not very often)
