Purge of material at start
Gigi
Posted · Purge of material at start
No problem with AA core.
The purge make a big bubble to the buildplate then rise and everything ok.
BUT...
BB core make a bubble then rise a bit and wait too much and another bubble is growing and stick to the nozzle then is carried out to the print zone.
I think that for BB core rising a little bit will be an option ?
    Hello,
    New ultimaker user :) I confirm I saw the same issue with my last print. I had to quickly remove the PVA blob manually when the print started. But with remote usage this is an issue...
    I will try the new Cura :)
    Ok.
    Purge at start is firmware or software ?
    Make the same routine for BB core as the one for AA core.
    That is like Achilles heel.
