I think I remember hearing that this is fixed in Cura 2.5 beta.
1
It was definitely worked on, I just loaded 2.5 beta today. Now it comes down and squashes the prime prime pile with the carriage.
Here is the unmodified GCODE around the prime extrude for nozzle 1 which in the case of this print was after the prime pile and brim was printed in PVA from Nozzle 2:
(Please note I moved the Nozzle 1 prime location so that I could see it better on the camera)
T0
G92 E0
M109 S245
M104 T1 S0
G0 F5000 X213 Y207 Z0.27
G0 X162 Y6
G0 F15000 X162 Y6 Z2
G280
G1 F1500 E-6.5
G0 F5000 X162 Y16 Z0.27
It is the last line shown above that moves the carriage in the Y direction 10mm from the prime pile and sits the carriage back down in it. if it just would have gone to X112 before sitting back down to Z0.27 it would have been fine, It'd be even better if they put a 2 second dwell in there for the nozzle have time to ooze onto the build plate.
So the Gcode would then be:
T0
G92 E0
M109 S245
M104 T1 S0
G0 X162 Y6
G280
G1 F1500 E-6.5
G0 F5000 X112 Y6
G0 Z0.27
G4 P2000
I CAN edit the GCODE but it would be awesome if there was no edit required to trust printing without having to run to the machine if a prime pile gets picked up.
Also adding a short dwell after the nozzle 2 prime would be awesome too. I even added a move to z30 then a -50mm Y move then move to z2.27 with a 2 second dwell, this worked awesome to get the ooze of PVA to attach to the build plate.
I just moved to Cura 2.5 and still the same issue for me (exactly what happens in the video). So I also end up waiting for the print to start, and "catch" the prime blob to prevent it to be dragged over the print area.
Ultimaker team, you need to do something to help us
That's 1cm from the starting position of the prime! That should never catch the prime poop.
I can't imagine that that gcode catches the prime poop.
I had the same issue. Updated the firmware about a month ago which has solved the problem for me.
Very weird.. running 2.4 on a few UM3 and we don't have that issue... At least i never noticed it and it never caused an issue if it is happening... O_o
Hello,
Something that may be interesting to notice : I'm currently testing some dual color PLA prints, and I don't have the issue at all with PLA. It seems to occur only with PVA. Since flow control is not exactly the same for PVA and material "glues" more to the print head, that may deserve a special treatement in the slicing / printer init ?
You don't have to imagine it catching the prime poop, watch the video above
The problem is it goes from Z2 to Z0.27 before before it goes from Y6 to Y8 or so.
Cura 2.5 helped but it still sits down and catches the prime pile with the fan shroud sometimes. It mainly does this on the nozzle 1 prime pile.
we updated our firmware about 2 weeks ago things were better but still have to at least watch both nozzles go through prime sequences. It happens a lot less with new firmware and cura 2.5 beta but when it does happen it ruins the print.
XYZDesignPro 70
Happens every time I print support with PVA. I've never printed any other material in core 2. I've simply resigned myself sitting by the machine waiting for the material change to core 2, watching the prime process and at the proper time, I grab the prime pile with a pair of really long tweezers and hold it in place.
Not very high tech, nor elegant, but beats the hell out of ruining a print in the first 3 minutes and having to start over.
This has been going on since firmware 3.5 and Curs 2.3. I keep hoping it will be remedied with each release. Alas, no joy . . .:(
