I agree with gr5, bigger nozzles is what you need. Expect 0.8mm from UM within 2 months. With a 0.4mm nozzle, 0.3mm layers is really pushing the limits.
Please note that the Cura default profiles are a coherent set of settings. If you change things like the layerheight, and printing speed, the profile is not optimal anymore. You may want to increase the printing temperature for example, to prevent underextrusion.
An interesting option may be gradual infill, but that depends on what you use the infill for. Infill can have 2 goals: strength, and something to carry the roof of the print.
If you care mostly about carrying the roof, gradual infill can really speed up your print. It uses a low % of infill in the bulk of the part, and only increases the infill-% in near the roof in a few steps.
I notice in your picture that I can see the PVA through your part. Your part has no bottom there, is that supposed to be the case?
gr5 1,872
To save time printing large models you should strongly consider larger nozzles. Ultimaker is likely coming out with a 0.8mm nozzle soon (it's in cura anyway) and 3dsolex sells .8mm nozzles and 1mm nozzles and maybe larger. Look into the "hardcore" at 3dsolex.
You can print .6mm thick layers with a .8mm nozzle. It won't look as pretty (kind of like a stack of pancakes).
