What happens on the next layers if you continue printing? Does it keep extruding so irregularly, or does it level out nicely?
It appears to print nicely after the first layer. Its difficult to tell because its mostly infill.
I sometimes see a bit of irregular extrusion too in one of my printers, but only on the first layer, although far less than yours. Then it smooths out. So I don't really care, as it is only one layer.
It makes for a very rough, ugly bottom. Its not really an acceptable solution.
I am not sure what causes it, but I guess that in the beginning the temperature is not yet totally stable, or that there are variations in molten volume in the nozzle, since you don't have a nice steady stream of filament yet in the beginning. I guess it is like in a chemical plant, where you always have process variations and swings on startup, until all distillation columns and equipment is on temperature, and a steady flow is established? Then things smooth out.
I am relatively certain that this is not its cause. If this were the case then printing a small part would have even worse issues (and they would likely persist past the initial layer). Its actually the opposite. Smaller parts print perfectly, first layer and all.
But of course, there could still be other causes, such as a worn-out coupler
I recently replaced the coupler with a new one from 3d solex. I am not sure what the coupler does, or how it could cause this issue, but the one I have is pretty new. It looks perfect when I disassemble the extruder.
or filament that has trouble sliding through the bowden tube smoothly, so that pressure builds up irregularly, and then it jerks forward? Or something similar?
This is actually what it sounds like. My working theory is that the smaller parts I print have more retractions so the filament is moving back and forth more often, where the larger parts print in longer runs with no retraction, giving it more time to "stick" to the bowden tube. While its doing this, its slowly running out of filament (I actually have seen some thinner than normal sections that give more evidence for this), and then the push when the pressure is enough to overcome its friction is responsible for the flood of filament.
What happens if you print a skirt of 30 lines around the object, just for test?
I plan to try and oil the bowden tube to try and get it to slide better and see if this solves the problem. I have read that some people have had success with this on other printers. I will try a large amount of skirts if this doesnt produce better results.
geert_2 545
In some brands or colors of filament, this effect is much stronger than in others. Also, when the nozzle is leveled rather close to the bed, to get a smoother bottom layer, the effect is stronger.
But of course, there could still be other causes, such as a worn-out coupler, or variations is filament diameter, or filament that has trouble sliding through the bowden tube smoothly, so that pressure builds up irregularly, and then it jerks forward? Or something similar?
