kmanstudios 1,120
Ultimaker just came out with the stuff, so I would think it is under the experimental phase at the moment.
Polypropylene is very chemically resistant because it doesn't interact with most other materials. This is a nice property but also has some downsides:
- It doesn't stick to other polymers (so no PVA)
- It's hard to stick PP to glass, with small prints it's possible but bigger prints need adhesion stickers
From some practical tests I can say that PP does not stick on PVA as @Tomhe wrote. So forget this combination for large horizontal overhangs or 'islands'. However, I managed to print a small object with PP and PVA support which had well connected PP layers and just needed the PVA as a bed so no PP line hangs on the bottom side.
Thanks for the info everybody! I didn't want to waste PP on supports, but I guess I have to now.
fbrc8-erin 267
It looks like it's not supported with PVA according to the latest table on the compatibility chart: https://ultimaker.com/en/resources/49799-material-compatibility
PVA only seems to be supported with CPE, PLA, and Nylon. It says TPU, PC, and ABS are considered experimental/use at your own risk, but my impression has always been that PC and ABS do not adhere well to PVA.
