AHH! Thank you that makes sense!
kmanstudios 1,120
What if you are using the print core 0.4 (I neglected to get a BB Core 0.8mm), what would happen using your advice?
Edited by GuestABS seems to print fine with the 0.4mm core. However even with the larger layer thickness (0.4mm) ABS still prints very poorly. PLA Seems to print just fine with the same setup though.
I noticed when I was switching filaments the ABS was bubbling heavily as it was freely extruded from the print head. @Tomhe Could this be the root of my poor prints with ABS? Should I bake the ABS prior to printing with it?
- 5 weeks later...
I have a similar problem
I just could not got my UM2 Extended with Ollson block upgrade to print proper using the 0.4 nozzle. I used now the 0.6 nozzle with ABS
Top Layers 4
Bottom Layers 3
Sides 2
Bed Temp 100
Nozzle temp 230
Print speed outline 65
Print speen infill 70
I increased the material flow to 110%, no improvements
I inclreased the temp to 250 - no improvement
I reduced the speed to 90%
I reduced the temp to 220
Note of these resulted in any ideal improvements, in fact reducing the temp given even worse effect.
seems the filament is just not giving the glossy smooth texture. but I tried other ABS and having the same problem.
I thought of even replacing the print head to E3D, but do not want to spend money if I do not know what the real problem is. I am nou guessing.
I also have a Creality CR10 s5, and the fist print was perfect.
I am using Simplify 3D. With Cura I got the same texture.
Just yesterday I tested out the ABS filament I baked for 5 hours at 150F and it worked perfectly with the 0.8mm core.
Tomhe 21
Hi Rossboss,
Sad to hear you don't have good results... I would try printing it at 0.3mm or 0.4mm layer height if you have issues with curling edges on overhangs. We do have profiles for those layer heights; these profiles show up if you set both printcores in Cura to 0.8mm printcores (so for the unused extruder as well).
Printtime will decrease a lot as well .
