kmanstudios 1,120
I can attest that humidity is a major problem as at the very least, moisture can build up in the bowden tube and that can create issues. Also, while I am not sure about PETG being hygroscopic (there seems to be varying themes around about that) I did run across a bit of info about this here.
A short snippet:
PETG is hygroscopic, which means it will actively absorb moisture from the air. For this reason, PETG plastic should be stored in a cool, dry place, and dried if exposed to humid air for too long. What constitutes “too long” depends on the relative humidity in the air, but when it comes to 3D printer filament, it’s best to err on the side of making the filament “too dry” rather than allowing it to be a “little wet.”Printing wet PETG can lead to hydrolysis which will permanently alter the filament on a molecular level, making it significantly weaker than it would be if it were printed dry.
I have also seen some places say that PETG is a bit more brittle when humidity attacks it.
Most of my worst failures in printing can be directly attributed to humidity. A lot of the other can be user error and a tiny amount of WTF? Hey, what is life without a problem to solve and a mystery to confound?
Top Posters In This Topic
42
21
15
2
Popular Days
Aug 3
8
Aug 14
7
Aug 23
6
Aug 15
6
Traveler218 42 posts
kmanstudios 21 posts
SandervG 15 posts
Dim3nsioneer 2 posts
Popular Days
Aug 3 2017
Aug 14 2017
Aug 23 2017
Aug 15 2017
Posted Images
Traveler218 1
I checked the spool and the way it is feeding, there does not appear to be a problem with that. The spool sits on a set of 608 bearings and rolls freely, with nothing obstructing the path. The edges of the spool are smooth and the filament comes off without catching on anything.
Humidity can get high in this building and yes, they turn off the A/C at night. I hadn't really considered that as a problem. The UM3 is situated close to an A/C vent. I constructed a box to block the top and front of the unit when I was having warping problems with ABS. Lots of open space above and on the sides, but it prevents direct drafts from the A/C. It seems to help the issue. We should probably invest in the advanced printing kit, but haven't been able to spend that money yet.
I'll have to check into that last one. I used air to try and clean it out, but have not taken it apart to check on build-up on the knurled pattern.
