kmanstudios 1,120
Have you tried an ooze shield?
Hi Kmanstudios, I didn't knew about that option, it was hidden by default in Cura. Thank you for your idea. I found some videos on YouTube and also the parameter in Preference/Configure Cura/Settings/Dual extrusion/ Enable ooze shield!
I will try that!
No problem. I am glad you found it. I forgot it was hidden by default since I have had all my controls opened and available since first starting. I could not tell you what is hidden or not anymore. Duuuuhhhhhh.......
Good luck with the ooze shield.
To be honest, the worms do not bother me as I am making display pieces for the most part at this time. As gr5 said, it will leave tiny pin prick holes in the surface when dissolving the PVA, but it is either too small for a raw piece, or it will be covered in primer and such if I am 'finishing' the model.
Edited by Guestare you using the latest version of Cura? There is continuous improvement on the printing profiles, which are shipped with Cura. Especially PVA printing has improved a lot.
Hi Tomnagel,
I am using Cura 2.6.2 for win64
Are you using 2.7 beta?
Thanks.
gr5 2,071
My biggest problem with the worms is they sometimes cause holes in the wall of my model after they are dissolved.
A wipe tower helps but has learning curve. Mostly I suggest put the wipe tower in the back center as it is less likely to fall over there. Wipe towers tend not to stick well in the back corners.
OlivierV 1
Thank you gr5, I will try to use a wipe tower and will put it in the back center.
