.... I am printing PETG and have found that first layer adhesion is helped hugely by raising the nozzle 0.1 or even 0.2 mm above the normal first layer height. PETG doesn't seem to like being squished onto the build plate.
I have found the same thing. On my Robox printer I have the ability to go in and raise the Z-offset , .05mm seems to work well on that printer. However, with the Ultimaker 3 Extended, I have not found a way to adjust this setting in Cura. You say you have recently made a mod to cura to accommodate this, would you be willing to share this mod?
burtoogle 510
Hi, that's an interesting idea and it may well be worth investigating.
Here's my experience.... I am printing PETG and have found that first layer adhesion is helped hugely by raising the nozzle 0.1 or even 0.2 mm above the normal first layer height. PETG doesn't seem to like being squished onto the build plate. I don't mean use a thicker layer but keep the layer thickness the same and raise the nozzle. Some printers provide you with a way to raise/lower the nozzle manually (aka baby-stepping). I can do that but have recently created a mod for Cura that let's you raise/lower the nozzle from a setting in Cura so you don't have to remember to fiddle with the printer controls. For me, that makes a big difference in the quality of the first layer when using PETG.
