Hi @Dennispo, thank you for your reply.
Your heated bed is basically your build platform. So your Z-stage+glass bed. A build platform can be either heated or non-heated. Among some other of the 3D printers you seem to have, your Ultimaker 3 has a heated bed. It means that it can heat up, which can improve the adhesion for some materials and prevent other failures.
If you heat it up and follow the previous instructions, the heat coming from your build plate can vaporize the moist in your PVA. Let me know if this is not clear
Here is also a picture with the arrow pointing to your heated bed: http://take.ms/0iiKg
kmanstudios 1,120
I have had all of that happen due to humidity. The material smokes because it is boiling out the moisture.
Also, when it gets too moist, it binds in the bowden tube a bit and the material is too soft for the gears to push it through. That is when you get the bent up shapes from the material acting a bit like a wet noodle.
For instance, we have had a mild summer with many nights and even days I could have opened the doors, but it was too humid to do so. Thusly, I have had to run the A/C all the time to dehumidify the room air until the outside air cools and dries out more.
SandervG 1,518
Hi @Dennispo, do you have any way to measure the humidity in the space where you print and store your PVA? How do you store your PVA?
If it is too damp, you can use these instructions to dry it again:
Heating the filament for 2 hours at 45 - 55 °C. The easiest way to do this is by putting the spools in their original packaging (in the cardboard box, without a plastic bag) on the heated bed at the required temperature (45 - 55 °C). Warning: do not use a household oven. Make sure that the PVA filament has cooled to room temperature before inserting it into the 3D printer.
RudydG 62
PVA and Nylon are very sensitive to humidity.
I just bought a big fooddryer, to dry my filaments (after having the "steaming" trouble with an almost full reel of ultimaker Nylon)
Dryed the nylon for 14 hours at 75 degrees celcius, and now it seems fine again.
The pva is also dried, but didn't test it yet.
I am drying all of my open reels, and after drying, i put them in a plastic box with 1kg of silica gel (the color changing type), and hope to keep them in good condition that way.
dennispo 6
