Sorry i do not whant this. Id like to install my parts and only whant to know if it works or what can be a problem.
i whanted something like that but without Watercooling:
https://www.mm-3dprint.de/umbau-kit/
Edited by GuestSorry i do not whant this. Id like to install my parts and only whant to know if it works or what can be a problem.
Edited by Guestshort answer, just installing 2 blocks/nozzles in the UM2 head does not work. It's a waste of time to do it. Main issue, you need some kind of lifting system to avoid the unused nozzle to touch the print, or use 2 separate heads, like Mark2. Cooling is another issue.
Ahh ok now it make sense. So if i solve the lifting issue then cooling is not enough for two nozzles for the teflon?
Ok i lay the dual Print to the Graveyard.
I thought it was only a Power Problem and Firmware.
I did not think about lift the unused Nozzle.
Thank you very much now i know it.
Its to bad that no official Ultimaker 2 Dual mod is from ultimaker.
Why so pessimistic? The Mark2 is a really nice add-on. You might want to give it a try.
RudydG 62
My dear friend, do a search on the mark 2 project, it is just what you ask!!!
8 hours of printing, 1 small extra print incl. some cabling, and you are ready to go.
Everything is done for you ;-)
Happy dual printing!
