tinkergnome 917
Is there no way to control the preheating behaviour? :(
Hi JackTheSlicer,
i can only guess that you're talking about Cura 2.7, but which printer...?
...and i assume that you don't want to use a prime tower or an ooze shield for a reason...?
There are machine settings in Cura, named "machine_nozzle_heat_up_speed" and "machine_nozzle_cool_down_speed". AFAIK these settings are not accessible from the GUI. Ultimaker uses them for the profile configuration files in the subfolder "quality".
So: either override this settings in your printer's definition file, or create a custom quality profile according to your combination of material, printer and variant. If you use an Ultimaker brand printer, you can take one of the existing files as an example.
(e.g. "...Cura 2.7/resources/quality/ultimaker3/um3_aa0.4_CPE_High_Quality.inst.cfg")
I never had a need to fiddle around with this, so: no guarantees...
If you've created a new profile there should already exist a file in your configuration folder (in Cura: "Help" -> "Show Configuration Folder", subfolder "quality")
Add two lines like this in the section [values] and try it out.
... [values] machine_nozzle_cool_down_speed = 0.85 machine_nozzle_heat_up_speed = 1.5
JackTheSlicer 0
