Cura 2.7 problem with scaling
sofles
Posted · Cura 2.7 problem with scaling
Hi there I have a problem with cura 2.7, when I try to scale an object it looses outside walls (see attachment) in this case when I scale it to 37% it has all walls but at 36% it looses outern walls. This isn't happening to all objects but is very annoying. I checked the same model in ideamaker and slic3r and it scale without any problem even to 20% but I prefer to using Cura.
Thanks for any sugestions :)
5a333fabd2045_Zrzutekranu2017-09-29o14_30_01.thumb.png.7c5e9def6c9fa2b6d5cdfc1953883aca.png
5a333fac156bb_Zrzutekranu2017-09-29o14_29_50.thumb.png.730c504c1285cbb268de1a6941e2a02f.png
    There is a minimum part thickness that can print. Typically if the nozzle is .4mm the minimum wall width is around the same I believe with cura 2.7.
    Try changing ALL the line widths to .3mm for a .4mm nozzle (that's about the minimum you can go down to and still get reasonable quality). Or consider using a .25mm nozzle.
        • 4 replies
