kmanstudios 1,120
Try the "print thin walls" option in the hidden tabs. You can open preferences and unhide a ton of settings I see you still have hidden.
gr5 2,230
There is a minimum part thickness that can print. Typically if the nozzle is .4mm the minimum wall width is around the same I believe with cura 2.7.
Try changing ALL the line widths to .3mm for a .4mm nozzle (that's about the minimum you can go down to and still get reasonable quality). Or consider using a .25mm nozzle.
